0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#111511 07/01/2004 1:06 AM
I joust received my new hood hinges from Chevy Duty and they are Zinc plated like the screws at the hardware store (not galvanized). Would it be best to paint them to protect against rust?
Thanks for your help.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#111512 07/02/2004 3:25 AM
All the Taiwan stuff I get rusts like crazy if you don't paint it. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#111513 07/03/2004 6:05 AM
Johnny - zinc plate is galvanized - they were cad plated originally I think, and prolly the ones you got were too - the repro ones I got for my 58 were, and they won't take paint well
#111514 07/03/2004 12:13 PM
You're right! They're probably cad plated. I'll put 'em on and see.
Thanks guys
#111515 07/06/2004 7:12 PM
Cadmium plating is kind of goldish in color. Cad plating is going away within the next couple of years due to environmental restrictions. My company used to use cad plated screws in assembly and had to switch to stainless steel. This is fine for corrosion protection but the production lines were relying on magnetic pick and place, so differant equipment had to be used.
Paint & Body Shop moderator
#111516 07/08/2004 2:25 AM
These are silver in color and not a hint of gold. I stripped the paint I put on earlier off ( chemically ) and installed them Monday. As I said originally they look just like the bolts and screws you buy at Lowes Pretty silver color and not at all like hot dipped galvinized bolts.
I'll let you guys know how well they hold up here in Texas with out paint.
#111517 07/08/2004 9:53 PM
They're probably just zinc plated and not hot-dipped. The hot dipped plating looks a bit differant, you can see various patterns in the metal and it's not shiny. I would expect your hinges to rust in a couple years.
