1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2003 Posts: 86 | I joust received my new hood hinges from Chevy Duty and they are Zinc plated like the screws at the hardware store (not galvanized). Would it be best to paint them to protect against rust? Thanks for your help. John
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | All the Taiwan stuff I get rusts like crazy if you don't paint it. Brian | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Johnny - zinc plate is galvanized - they were cad plated originally I think, and prolly the ones you got were too - the repro ones I got for my 58 were, and they won't take paint well
Bill | | | | | Joined: Nov 2003 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2003 Posts: 86 | You're right! They're probably cad plated. I'll put 'em on and see. Thanks guys John
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Cadmium plating is kind of goldish in color. Cad plating is going away within the next couple of years due to environmental restrictions. My company used to use cad plated screws in assembly and had to switch to stainless steel. This is fine for corrosion protection but the production lines were relying on magnetic pick and place, so differant equipment had to be used.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2003 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2003 Posts: 86 | These are silver in color and not a hint of gold. I stripped the paint I put on earlier off ( chemically ) and installed them Monday. As I said originally they look just like the bolts and screws you buy at Lowes Pretty silver color and not at all like hot dipped galvinized bolts. I'll let you guys know how well they hold up here in Texas with out paint. John
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | They're probably just zinc plated and not hot-dipped. The hot dipped plating looks a bit differant, you can see various patterns in the metal and it's not shiny. I would expect your hinges to rust in a couple years.
