| | | Forums66 Topics128,115 Posts1,056,625 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 1 Moderated | | Moderated Joined: Jul 2015 Posts: 1 | I have a 1948 Chevy pickup with a 235 and a 4 speed tranny origional driveline. How do I get the slop out of my shifter. .?A lot of slop back and forth | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Welcome to Stovebolt.com, Dave 2 Here are two possibilities: - floor shifter boot (not original equipment, but it helps diminish the rattle) - there is a spring at the top of the shifter arm/handle (that spring is "cut-away/through" in the diagram - maybe that spring can be "expanded" to be tighter in the housing/cover) | | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | I had the same problem with my 52. I Removed the shifter, drove out the two pins on the side of the tranny neck and inserted two larger roll pins. This made up for the wear in the shifter and took out a lot of the slop. Both the original pins and the shifter slots wear over time partially due to constant pressure on them by drivers keeping their hand on the shifter while driving. Good luck.
1952 Chevy 3100 Semper Fi !
