0 members (),
52
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 29 | On my 1950 3100 I bought front bumper brackets off e bay , but when I install them ( bolts line up on frame properly )and go to install the original metal splash pan, it looks like everything, face bar and pan are about 2 inches too far ahead I thought all the brackets were the same.. any thoughts | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Do you have the rear bumper on the front by mistake? The rear bumpers have much less arc to them.
| | | | | Joined: Mar 2014 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 29 | Thanks for your reply Carl , but no these are front brackets,In my earlier post I said 2 inches but its probably a little more than an inch | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Are you talking about the gap between the splash pan and the grill/fenders???? http://www.pbase.com/dennygraham/image/1607553431" is about right. dg
Denny G Sandwich, IL
| | | | | Joined: Mar 2014 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 29 | Denny .. yes thats what Im talking about .. mine is somewhat wider but maybe not as bad as ai thought , and might be better when everthings tight ,,,thanks for the photo Fred | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | I am with Denny, just install mine and thought it did not fit right but after everything tightened up looks OK. root | | | | | Joined: Mar 2014 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 29 | got my front bumper / filler bolted on , It has about 1 1/4 inch gap but looks fine and was not much problem installing ... thanks everyone for your replys....Fred | | |
