5 members (TUTS 59, WICruiser, 2-Ton, jmoore, dunfire), 123 guests, and 1 robot.
Topics128,048
Posts1,055,541
Members48,425
#1113860 07/15/2015 4:57 PM
On my 1950 3100 I bought front bumper brackets off e bay , but when I install them ( bolts line up on frame properly )and go to install the original metal splash pan, it looks like everything, face bar and pan are about 2 inches too far ahead I thought all the brackets were the same.. any thoughts
Do you have the rear bumper on the front by mistake? The rear bumpers have much less arc to them.
Thanks for your reply Carl , but no these are front brackets,In my earlier post I said 2 inches but its probably a little more than an inch
Are you talking about the gap between the splash pan and the
grill/fenders????
http://www.pbase.com/dennygraham/image/160755343
1" is about right.
dg
Denny G
Sandwich, IL
Denny .. yes thats what Im talking about .. mine is somewhat wider but maybe not as bad as ai thought , and might be better when everthings tight ,,,thanks for the photo Fred
I am with Denny, just install mine and thought it did not fit right but after everything tightened up looks OK. root
got my front bumper / filler bolted on , It has about 1 1/4 inch gap but looks fine and was not much problem installing ... thanks everyone for your replys....Fred
