2 members (cmayna, Gray_Ghost),
168
0
Mod | | | Forums66 Topics128,114 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | I'm moving 150 miles from San Antonio and of course, my 55.2 GMC 100 is coming with me. I was going to put it on an auto transport from uhaul or penske but after talking with both of them yesterday, the representatives said my 55.2 was too heavy for their trailers and it was "not recommended" for my 55.2 to be pulled behind my 2011 Yukon.
I'm now shopping auto transport companies and so far the quote is about $500. Anyone used a uhaul or penske transport before for their pickup and if so, any issues?
After doing my own research, not sure why either transport won't work:
Weight of my 55.2 (and this is an estimate as my 55.2 sits on a frame from a 1978 Blazer and has a 350 with a turbo 350) = 3375 lbs Weight of the trailer = 2210 lbs Weight of yukon = 5817 lbs
So the yukon is only 300 lbs heavier than the trailer and 55.2.
1955 GMC 100 Series 2
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | It is the weight of the trailer and what is put on the trailer.
The weight of your tow vehicle does not get added in.
Your truck should be able to pull your 1955. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | If your truck is a roller you might consider a tow dolly instead of a full trailer. I know several on here don't like them but thousands of people have put millions of miles on using them. Used properly they are safe and cheaper too. Your only pulling 150 miles not from coast to coast. Good luck with your move.
| | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Not a bad idea Martin, but I have a small leak in the rear end and I'm not comfortable using a dolly. Just a personal preference.
| | | | | Joined: Feb 2013 Posts: 614 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 614 | Have the mrs. Drive the Yukon and you drive the 55. If you got them, drive them! | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Tell them you are pulling an S-10 or a Ranger.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | It is the weight of the trailer and what is put on the trailer.
Your truck should be able to pull your 1955. Yes, it does. It's called Gross Combined Vehicle Weight. I sold trailers for several years, so I know this to be a true statement.
| | | | | Joined: Jan 2015 Posts: 32 New Guy | | New Guy Joined: Jan 2015 Posts: 32 | Your 55 weighs no more than an average sized modern car. My 2009 4-door weighed 4000#. If a 2200# trailer can't carry a 3400# car there is something seriously wrong with it, but I can see U-Haul putting an unreasonably low rating to protect themselves from lawsuits. Do they post an actual weight rating, or just told you it couldn't handle it?
Even without all the specs on the Yukon, I still can't imagine it not being able to handle the load either (presuming it's in good repair).
Thanks, David
| | | | | Joined: Mar 2010 Posts: 10,293 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,293 | If you have the proper hitch, you could pull your house down the road with a Yukon. U-haul and Penske are being ridiculously over-cautious.
| | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | U-Haul hears pick-up and they jump on the thought of a full size modern pick-up weighting in at 7000+lbs.
I have played this game with U-Haul before using a Tahoe to tow a old vehicle.
Drive the truck to your local scales and get a certified weight.
Take the paper with you to pick up the trailer.
Your Yukon i s rated but only if properly equipped, which means for that load level either get a trailer with brakes electric or surge. If you have the proper tow connector and built in brake controller on your Yukon then electric brakes, if not then you need a surge brake trailer.
If your just going 150 miles then lube up the rear end and us the tow dolly. Heck $500 you could likely buy a fair used dolly then sell it after your done.
If you search the rags want add you likely could find a used car trailer cheap enough and then resell it after done using.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Yes, it does. It's called Gross Combined Vehicle Weight. I sold trailers for several years, so I know this to be a true statement. When Chevrolet sells a truck the tow rating they list is the weight that truck can tow. Which is the trailer weight and the loads weight on the trailer. GCVWR is different then GVWR. GCVWR deals with license requirements, and DOT numbers.
| | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | We pulled our second 1954 3100 from Kansas to Florida on a U-Haul car trailer using a 1996 Ford Bronco without any issues and safely. The key is to tell U-Haul that you are towing something different than an old pickup on the trailer - I told them it was an Escort that was being towed. They gave me the trailer without any questions. Samantha | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That just sounds odd. When I brought mine home from Marietta, GA, I told them (U-Haul exactly what I was hauling, and what I was using to pull it with. No problems at all, other than they couldn't find the records of where I had reserved the trailer (had them call my local U-Haul rep, no problem after that). I would think if you tell the you're hauling something different that what you are really hauling, that will cause you major problems getting compensated should a problem arise. Say, if you were hauling your GMC, but told them it was an Escort, all they're going to compensate you for is an Escort. Or worse, you could end up with nothing, as they could easily say that you "overloaded" a trailer with a heavy truck instead of the lightweight compact you claimed was on there. Honesty really is in the best interest of both parties.
Bill Burmeister | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Longbox, Maybe it has to do with the local Uhaul office. One wouldn't let me tow my 54 on their trailer, even though the Bronco was rated to tow 7K. Samantha | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's my thoughts. I would try a different office.
Bill Burmeister | | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | Given the relatively short distance of 150 miles, I wonder if a tow truck operator using a flat bed would be an option worth considering. The rent hassle, loading, fighting traffic and unloading would be minimized or nearly eliminated. | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Sent you a PM. We're thinking of the exact setup to transport (unexpectedly) Shelley to AZ...
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | In my experience as a professional truck operator, most folks load their trailers too nose-heavy, and therein lies the root of U-Haul's problem.
All trailers and all tow vehicles have a maximum tongue weight which should not be exceeded. If DADS50's load was to be pulled by a Yukon, I'd load it a bit further back - or backwards - to get weight off the hitch: Ideally, the CG of the load should be 1" forward of the centre of the trailer's axle group. The loaded tongue weight should be only slightly higher than the empty tongue weight.
Don't neglect proper securement: cross-tie the load. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jan 2015 Posts: 32 New Guy | | New Guy Joined: Jan 2015 Posts: 32 | That's interesting. I've always heard that 10% of the loaded trailer weight should be on the tongue. Maybe they err on the high side because most people are not going to be able to get so close, and too much weight on the tongue is way better than negative weight?
I'll never forget the trip I once made hauling some lumber on a (U-Haul) car hauler. The lumber was up to 2' longer than the deck, and since it had that railing both sides and across the front I couldn't move the lumber far enough forward to get any weight on the tongue. VT to WV I couldn't exceed 50 MPH without getting terrible trailer sway. Thankfully, at the time the speed limit was still the Federal double nickle so I wasn't too much of a road block.
Thanks, David
| | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | So after all this, turns out my AAA membership will tow the truck 200 miles for me, on a flat bed. So my yearly membership just paid for itself.
| | | | | Joined: Jun 2015 Posts: 68 'Bolter | | 'Bolter Joined: Jun 2015 Posts: 68 | Really? I thought about doing that but since my truck was 1. not registered and 2 Running I figured it was not within the realm. I assumed that the towing was for the case of a breakdown. Can you give details? Thanks Chuck | | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | We have the "premier" account with AAA, have been with them for over a decade. With that account, each account holder (my wife and I) get 4 tows per person, per year, and one of those tows can be up to 200 miles one way. I've used them before to take the truck to the local shop when I had a bunch of work done, and there is no charge. It doesn't have to be running either, and it doesn't even matter if you are the owner of the vehicle. The AAA service follows the member, not the vehicle. Towing Service With AAA Premier, each household can have an auto towed up to 200 driving miles from the point of breakdown, as one of the four allowable service calls per membership year, and up to 100 driving miles on the remaining allowable service calls. http://ww1.texas.aaa.com/en-tx/become-member/online-member-kit/Pages/premier-benefits-guide.aspx
| | | | | Joined: Jun 2015 Posts: 68 'Bolter | | 'Bolter Joined: Jun 2015 Posts: 68 | Live and learn. Thanks for the info, may come in handy next time. Chuck | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | GMTK;
How much is your annual membership. I couldn't find pricing on the web site you posted. I'm logging in from Kuwait, so that may be part of the problem.
When I return to the states next summer I plan to drive my 58 Suburban from KC MO to Rhode Island. Good AAA coverage sounds like a must have.
Larry
| | | | | Joined: Jun 2010 Posts: 300 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 300 | i just used uhaul this weekend and pulled a 1954 gmc long box with my 2012 gmc sierra 1500 crew cab drove 800 miles with no problem you have to tell them your truck will pull it. they told me it would not work i told them i had truck built to put my 30 foot trailer 6.0 eng 6 speed trans it worked fine for me | | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | GMTK;
When I return to the states next summer I plan to drive my 58 Suburban from KC MO to Rhode Island. Good AAA coverage sounds like a must have. I think we pay $125 a year for my wife and I. And the coverage follows us, not just the car. So if I'm in a buddies truck as the passenger and we break down, or (hypothetically) get stuck in a lot of mud because we made bad decisions - then AAA pulls us out for free. http://www.texas.aaa.com/home/membership/become-a-member/benefit-comparison.html
| | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Who ever it was at u-haul didn't know what they were talking about. I transported my 52 on a u-haul back in 04 on one of their trailers from Cali to Las Vegas. Pulled it with a half ton 2003 gmc | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | In 2008 I used one of their auto transporters to bring home my 1950 Chevy half ton. Pulled it with a 2006 Jeep Cherokee. No hastles at the dealership and no problems at all driving from Davenport, IA to San Antonio TX. Must be a dealer issue and not an edict from the U-haul home office.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | GMTK;
Hooah. Thanks. I'll remember to sign up before I get back to the states.
Larry
| | | | | Joined: Aug 2001 Posts: 3,607 Moderator | | Moderator Joined: Aug 2001 Posts: 3,607 | Think I'll check into it also and see if they also cover a 25,000+ pound, historic firetruck. One tow would pay for three years.
Thanks Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | You are well within the towing capacity of a Yukon. There are a lot of U-Haul dealers in San Antonio. Go to a different dealer and don't tell them what you are going to haul. And I don't know what direction you are going out of San Antonio, but you won't be getting into any mountains if you only go 150 miles. At one time I had a 5.3 GMC several years ago. I pulled a lot heavier loads on my own trailer with no problems. | | | | | Joined: Nov 1995 Posts: 5,729 24601 | | 24601 Joined: Nov 1995 Posts: 5,729 | For anyone who still wants to know the difference between Gross Vehicle Weight Rating (CVWR) and Gross Combination Weight Rating, Here it is from the Feds themselves: Gross combination weight rating (GCWR) means the value specified by the manufacturer as the loaded weight of a combination (articulated) vehicle. In the absence of a value specified by the manufacturer, GCWR will be determined by adding the GVWR of the power unit and the total weight of the towed unit and any load thereon. Gross vehicle weight rating (GVWR) means the value specified by the manufacturer as the loaded weight of a single vehicle.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | The sad part of it all is it really does not mean much in these values. I state this as to the fact a well know major manufacture of trailers built some custom trailers for a contractor the dept of defense under contract. The trailer manufacture sent trailer with tags that were not rated to the DOD requirements. This presented issue when passing weight station as the trailer was over loaded. So as the government agent we pushed for proper trailers, the trailer manufacture sent us new trailer tags stamped to the higher value. We fought with them but lost as a manufacture they set the load levels of the trailers they build. As John states "specified by the manufacture" (no federal standard).
So while a guy can get Lowes to load 4000lbs of block in the back of a old small toyota pickup, you can't rent a 5000lb trailer to haul a 3000lb vehicle.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Jan 2015 Posts: 32 New Guy | | New Guy Joined: Jan 2015 Posts: 32 | ...you can't rent a 5000lb trailer to haul a 3000lb vehicle. Explain?
Thanks, David
| | | | | Joined: Feb 2011 Posts: 12 New Guy | | New Guy Joined: Feb 2011 Posts: 12 | I rented a uhaul trailer tohaul my 50 3600 truck with no problems, told them it was to haul a 50 6 cyl truck, also hauled a 39 buick with one, they had to call the main office to be sure it would be within the weight limit. They did not want it to go out of state, I just did not tell them it was, and returned it to the original dealer. | | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | I don't know shinola about this, but wonder if Penske or some other competitor would be less restrictive and less hassle? | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | When I towed my 59 3100 from Charleston, SC to Knoxville, TN I put it on a trailer from UHaul and I pulled it with a Dodge Dakota (of course I told them I was pulling with a Chevy 2500). It tracked just fne the whole way back. Only issue I had was when I came down the mountain from NC into TN on I40, it kept pushing forward and engaging the trailer break..I just accelerated......:D
1959 3100 Apache Fleetside
| | | | | Joined: Nov 2013 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 38 | I have a '48, the weight is abut the same as a '55. I have trailered it several times with my 16' car hauler pulled with my '99 GMC pickup. Pickup has a 4.8 liter engine - the small V-8. One trip was 250 miles thru east Texas. "48 Pickup about 3500 lbs 16' carhauler 1200 lbs GMC pickup somewhere around 5000 lbs.
Your Youkon is slightly heavier that my 99 pickup Your Yukon engine is larger than mu 4.8 V-8 There is no reason your Yukon could not pull the trailer with the 55 on it. | | |
