1 members (RLB), 81 guests, and 1 robot.
Topics128,162
Posts1,056,940
Members48,458
#1114959 07/21/2015 4:52 PM
Does anyone have a photo of how they installed one of those glass bowl fuel filters on a 216? Where in the fuel line would be the ideal location? I'm thinking just before the carburetor. Right? Would like to see a pic if possible.
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
Yep, see here. It should be noted that I relocated the horn from the intake manifold to the inner fender. If the factory horn remains on the intake manifold, you would use a 45 degree angle fitting between the filter and carb in order for the fuel line to pass around the horn.
DADS50's link leads to all you need to know.
One item at that link is this illustration from an installation manual. It does not required cutting any lines and it avoids an intake-manifold-mounted horn.
Hey guys, thanks to all who responded!
I went on to Sheridan's '46 website Sheridan's 46 Chevy Truck and have decided to go with the fuel filter which is incorporated with the fuel pump which I can purchase from Jim Carter. This is more historically correct and just what I wanted. Tim has done an awesome job of documenting his restoration efforts! Ordered the fuel pump with filter and should receive it in a few days. Now I just need to find that S/S vacuum line!
David Wolff
1946 Chevy 1/2-ton
I used a glass sediment bowl filter with a shutoff valve that screwed into the bottom of the gas tank on my 39. This allows me to shut the gas off and clean the sediment bowl. My fuel pump also has a glass sediment bowl on it too. I never see any crude in the fuel pump filter.
Rick
1939 Chevrolet Stake Truck
Where do you get that angled inlet fitting?
1951 3100
My son's 1946 2 ton has a different carburetor though the fuel filter is hooked up the same as in DavidF's photo. Except when the fuel line comes around the front of the valve cover it has only one bend before it reaches the carburetor. And this truck has never been restored.
FWIW, I fabricated the fuel line on my truck the way I wanted it, not necessarily factory correct.
Also, I believe filter at pump or at carb are both equally "historically correct".
Gas Pumper
Gas Pumper
http://devestechnet.com/Images/Restorations/1950B/D50b00411lg.jpg
There are a whole lot more on the site, but this is how I did it.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
