2 members (walter74, 1 invisible),
102
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | I just picked up a 235 motor for my 52 1 ton. The serial number on the motor is KAQ159225. Does the KAQ designate this as a Canadian block? I found one little note in the casting sticky which leads me think so.
Adding info; Block 3835692 April 18 1952
Head 3835499 May 16 1952
Crank 3835501
The motor has hydraulic lifters as well. It was supposed to be from a 52 Chevy Belair, any thoughts?
Mark
| | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | Is there much to taking the hydraulic lifters apart? I have read a couple of posts on using a drill bit to trap the check ball and spring…Any special way to remove the clip?
Mark | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | Thanks Deve, I'll give it a go.
Mark | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The clips are really easy to remove and install. I used a needle nose pliers. Don't let any of them get away from you!  | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | Ya, nothing like oily hands and springs to keep you on your toes! Thanks Again
Mark | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | they are interchangeable. Problem is, the cam 'seats' to each lifter, so you can't just put them back anywhere. They must go to the slot they were in. Maybe you know that already.
I personally wouldnt use 11 of 1 kind and 1 of another. I would replace them for a complete set. | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | I did have them arranged in the order they came out…..until I knocked the tray over and the order was all mixed up. Do you know where I can get new lifters? I tried Summit to see what came up but for some reason I didn't get a result. I'm searching under a 52 Belair which should do it. One other question is could I go back to solid lifters from my original block?
Mark
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Hydraulics are much easier to maintain. RockAuto has them. Search under the engines year Belair to get the correct ones. You can also get sets off ebay now and then. I do not know if you can go from hydraulics to solids anytime you want. Someone else with more knowledge will have to chime in. | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | If you are still interested, the KAQ engine serial prefix does not seem to reference a Canadian model. K = 1952 year A = Passenger model Q = RPO 317 Model 2100 Automatic Transmission Option Tonawanda Plant https://www.gmheritagecenter.com/do...mation-kits/Chevrolet/1952-Chevrolet.pdf (p 46-53).
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
