| | | Forums66 Topics128,076 Posts1,056,009 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 20 'Bolter | | 'Bolter Joined: May 2015 Posts: 20 | When I got this truck, the heat tube that activates the automatic choke was just hanging down near/touching the exhaust manifold - is it supposed to be fastened some way, or does it just have the be in the neighbourhood? You can see the end in the second photo here between the intake and exhaust manifolds: https://flic.kr/p/vX93ujhttps://flic.kr/p/tidBVSAlso, the dial was turned quite a ways over towards "rich". ( Looks like about 60-70°) I'm pretty sure I read somewhere that it should only be moved about 3 notches in either direction when adjusting. Is that true, or is this much of an adjustment pretty normal? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Did 1949 Canadian Chevrolet trucks come with an automatic choke? 1949 Chevrolet trucks did not have an automatic choke as standard or as an option. Here is a "universal" choke stove assembly. | | | | | Joined: May 2015 Posts: 20 'Bolter | | 'Bolter Joined: May 2015 Posts: 20 | No, I should have mentioned that the engine is a 59-62 261 out of a Pontiac car. The carb is a Rochester BC off of an unknown 235.
Have to remember to add that every time I post something...
Sorry! <-- I'm Canadian. | | | | | Joined: May 2015 Posts: 20 'Bolter | | 'Bolter Joined: May 2015 Posts: 20 | Thanks for the link TC! So that part clamps onto the exhaust header then, I assume?
What is the fiberglass rope/wrap for?
Anyone have pictures of the Chevy version on their stovebolt? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2015 Posts: 20 'Bolter | | 'Bolter Joined: May 2015 Posts: 20 | Awesome, thanks TC. One more thing on my "make something up" list to get this engine running!  | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | No, I should have mentioned that the engine is a 59-62 261 out of a Pontiac car. The carb is a Rochester BC off of an unknown 235.
Sorry! <-- I'm Canadian. At least you have the steering wheel where it belongs and you drive on the CORRECT side of the road. | | |
