1 members (Otto Skorzeny), 52 guests, and 0 robots.
Topics128,092
Posts1,056,040
Members48,433
#1114624 07/19/2015 11:22 PM
I picked up a Carter YF 3200S thinking I would use it on a Chev 235. When I began to rebuilt it I did not find a metering rod. The jet is marked 120-155. My dilemma is 'what metering rod to use with the correct jet'?
Any info is greatly appreciated.
Solrak #1114711 07/20/2015 1:59 PM
Carburetion specialist
The original rod for Carter 3200s was 75-1556.
Which two cylinders do you plan on not using? wink
Jon.
The Carburetor Shop
Solrak #1114727 07/20/2015 3:08 PM
So YF 3200S is not a good match for a 235 ?
Solrak #1114734 07/20/2015 3:48 PM
Jon will most likely clarify his reply/question/comment?
Here is a list of Carter YF carbs and applications from Jon/DADS50.
Solrak #1114744 07/20/2015 4:59 PM
Always a good idea to check the application of anything before buying it (check the second line in my signature).
Carter 3200s was sold to Willys/A.M.C. for use on a 134 CID 4-banger.
The good news is: Jeep carbs are generally much more valuable than Chevy carbs; with a little searching, you might find someone wanting that carb (this is NOT a hint, I am no longer buying carbs).
Jon.
The Carburetor Shop
