3 members (jkreiner, cmayna, Wickedbass), 58 guests, and 1 robot.
Topics128,074
Posts1,055,914
Members48,429
#1114591 07/19/2015 8:29 PM
dx3
Offline
Excuse the silly question, but how do I remove the temp probe from the bolt? Is it just pressed in there or what do I need to do?
pic
Jonny
1950 Chevy 3600 w/ 54 235 motor
Ex Hall Monitor
Ex Hall Monitor
I'm not sure you can remove the the bulb from the bolt without cutting the capillary tube. Maybe someone with more experience with it than me will be able to help. Good luck.
dx3
Offline
Well I got the new line/probe in, so not sure how to attach it to the engine block?
that is a bushing adapter
try soaking it in penetrating oil to free it
Jonny, the nut is part of the thermostat assembly. I just replaced mine, so it's still fresh in my mind. The nut is the easy part! Getting the actual gauge out is a pain in the a--. Why do you want to remove the nut?
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
I am with DADS50 on this one. The adapter bushing is stuck to the sensor probe. I am guessing that you pulled this 47-52 sensor from a 54 to 62 235. Soak it and push it out. Don't pull on the tubing.
Carl
I apologize - I did not see the original "nut" up high in the photo. The lower "nut" in question is indeed the adapter bushing. (I will delete my earlier post). Soak and try to loosen the adapter.
Tim, that makes two of us! I just went back for another look and seen the factory nut up higher. I concur with Tim and Dads!!
In the DITY Gallery
Ex Hall Monitor
Ex Hall Monitor
Now that the link works I can see the issue as well. Good advise. I guess that's why 'they' say a picture is worth a thousand words.
dx3
Offline
Thank you gentlemen. A couple of squirts of PB blaster and it slid right out. Thanks again!
