5 members (Randy Baumann, TexasJim50, 52Carl, dt235sd, 1955 1 Series), 77 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#1114508 07/19/2015 2:45 AM
Finally got the engine to idle below 750 rpm, changed the PCV to the one thats recommended, V-237, now is idling at about 500rpm. When I removed the one I had install, about 16 inches from the crankcase it was all oily, sucking to much vac. 53 3100 root
root #1114559 07/19/2015 3:30 PM
Gas Pumper
Gas Pumper
It matters doesn't it? If the PCV is robbing too much vac at idle, it changes everything. For the V-237, out of the 20 inches on the compression gauge, you are only stealing 1 inch and it maintains positive ventilation throughout the spectrum.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
