9 members (3B, Bill Hanlon, JW51, 57 Drifter, Gdads51, Otto Skorzeny, Gray_Ghost, DennisM, rick46ia),
64
Mod | | | Forums66 Topics128,022 Posts1,055,362 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 47 | Rewiring 52 3100 and need to find the two grommets for the firewall. Think I found the larger one for the main harness grouping. I need the smaller one? Anyone know where I can get it or what is the proper size? Denis
Thanks Denis Used to drive Subs, prefer old rides
1952 chevy 3100, 5 window
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | You can start here or here . I'm not sure which you need; there are at least five: 1) Main harness 2) Vaccum hose 3) Speedometer 4) Starter wire 5) 4-hole for Choke & Throttle cables, Oil pressure, & Water temp In addition, you may need heater hose grommets. Good luck and have fun, Bill
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Dec 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 47 |
