0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1114055 07/16/2015 4:33 PM
Rewiring 52 3100 and need to find the two grommets for the firewall. Think I found the larger one for the main harness grouping. I need the smaller one? Anyone know where I can get it or what is the proper size? Denis
Thanks Denis
Used to drive Subs, prefer old rides
1952 chevy 3100, 5 window
You can start here or here .
I'm not sure which you need; there are at least five:
1) Main harness
2) Vaccum hose
3) Speedometer
4) Starter wire
5) 4-hole for Choke & Throttle cables, Oil pressure, & Water temp
In addition, you may need heater hose grommets.
Good luck and have fun,
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
Thanks Denis
