0 members (), 45 guests, and 3 robots.
Topics128,049
Posts1,055,637
#111328 03/31/2002 6:47 AM
hello all, i'm looking to buy a small sized sand blasting cabinet just to do smaller parts. i've seen stuff on e-bay but im not sure on the quality of these. does anyone have a small cabinet that they are happy with? what brands or features do i look for and where's a good place to buy one? I have the air compressor already. Thanks!
1948 GMC 250 Series Flatbed
#111329 03/31/2002 2:14 PM
Check out TP Tools in Canfield, Ohio. They have cabinets of nice quality and in all sizes. I bought my cabinet from them and it has worked out great. Anytime I need replacement tips or accessories the guys on the phone are very helpful.
www.tptools.com
1 800 321 9260
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#111330 03/31/2002 7:25 PM
Also try the following Harbar Friehgt Tools, they have the best bang for the Buck!
Modelman
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
#111331 03/31/2002 8:19 PM
I built a wooden one with metal liner from plans from TP Tools. I bought their gloves, tube, gun and vac port or they do have a whole part kit. I didn't get their window, had my own cut. I can send a pix if interested.
Use a flood or spot light made for outdoors in it or make cut-out above for flourescent light. Need lots of light. You'll need a vacumm on it too as the dust gets bad right away and you can't see inside in short time. Use a good water trap filter, big problem with water. Best not to use long hose on 'presser as it makes more water, faster. Don't make/get too small, you'll use more than you think! Mine is 48" wide! Harbor Freight one is OK, if you get bigger one, don't care for small ones. I made a heavy expanded metal floor in mine, heavier than most boughten ones. glad I did, sometimes hard to lift heavy objects into cabinet and you set them down kinka hard sometimes! :rolleyes:
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#111332 03/31/2002 8:56 PM
TP's website is great, and they are in Ohio, which is even better. i just sent in for a catalog. i was thinking about building one, but don't have a lot of time as it is to work on the truck. but just curious GL, how much did it cost you to make your own? A pic would be great if you have the time. Thanks all!
#111333 04/01/2002 10:20 PM
I'm with GL on this one. Bought the plans from TP and built one that's about 54" wide. I had the AD front fenders completely inside it. Cost about $400 to build and is equal in size to the one that TP sells for about $1300. Hint: build it in two parts so that you can disassemble it if you have to move. I build the leg assembly so that the cabinet nests into it and can be lifted out. TP says that PAR flood bulbs provide better illumination than fluorescent tubes.
#111334 04/22/2002 4:05 AM
1. Old freezer
2. Pair of gloves and glove gasket rings...
Can be ordered from TP tools
3. A funnel
for reclamation of media
4. 4 Pieces of 4 inch angle iron.... (scrap)
for the legs
5. 1 piece of 4" sch 40 pvc pipe 6' long
for dust collector to hook up to
6. 2 flood light fixtures
7. grate for media to fall through and parts to lay on for blasting (mine I
got from a mfg of prison and industrial screen doors, scrap was free)
8. dozen or so short pieces of 1"x1" various lengths of angle iron (scrap
for grate to sit
on and to hold window in)
9. One tube of silicone caulking for window sealing
10. Window ( I got mine from a old school bus)
11. Pop rivets to hold angle iron to insides of freezer for grate to sit on
12. Motor to vibrate media for return. (I used a tool etcher for engraving)
13. 5 Gal bucket to catch media in the return
14. 4 Casters (I got mine from a junk shopping cart at the local super
market) free
Tools required:
1. a 1/2 inch drill with a few bits
2. Skill/saber saw
3. Hole saw....for the dia of your media pick-up hose
4. Rivet gun
5. Caulking gun
6. welder ( to weld plates at bottom of legs for caster to attach to)
& also you will need a porta band or hacksaw I didn't mention this in my
original post.
First I removed all the refrigeration parts from the freezer.
Then I made the legs for it.(length will depend on how tall user is) Two
legs on one end are 1/2 inch taller than the other two at the other end...
this is to make it slant downhill to one side for media to return to drain
hole. I also connected the legs together with an "X" brace to eliminate it
from shaking. This brace runs diagonally from front leg to back leg of
opposite corner and welded it on, and tack welded it in the center where the
other half of "X" brace crosses.( you can make it run all the way around and
make a shelf on it if you wanted to.
I welded a plate inside the bottom of the angle iron for the casters to
attach to bottom of legs. Caster are off a shopping cart. Grocery store gave
me an old one in the trash out back of the store.
I then drilled the 1"x1" wide angle iron for rivets in the drill press.
(two hole per angle) and then took a hand drill and drill holes for them to
be riveted into place inside the freezer 4 inches off the bottom along the
sides about every foot apart...the angles them self are about 6" long,
these hold the grate for parts to lay on while blasting.
I then mounted a engraver ( what you etch you name on tools ect. with in the
bottom to vibrate the media to the funnel.
I then put a funnel onto the bottom of the freezer for the media to fall
back into a 5 gallon bucket that I mounted to the leg underneath at the
bottom.
To mount the funnel I just took two strips of sheet metal and made tabs to
attach to the funnel with a pop rivet and then attached the tab to the
bottom of the freezer with rivets also so the funnel was up against the
bottom tight, and used the drain hole for defrosting that was already in the
bottom of the freezer .
I got my gloves and glove retain rings from TP tools. You can order them on
the Internet at http://www.tptools.com . They are 7 1/4 " outside dia.
holes for the rings to fit into the cabinet. I just used them for a pattern
,drew a circle around them and then drill a hole in the middle of that
circle big enough for my saber saw blade to fit into and cut the circle out
and then mounted the gloves with the rings for them.
I then mounted 2 flood light fixtures inside for light ( these ole eyes
need as much light as I can put in it)..LOL. I put a receptacle box on the
outside for the light switch .
I then took a hole saw ( the dia. of the media supply hose to your blast
nozzle) and drill a hole just below the right glove hole just above the
grate inside.
Now I marked out for the school bus window . Make the whole 1 inch smaller
than the window on all side. Drill hole big enough for saber saw blade and
then cut it out.
Now I made angle iron clips to hold the window into place against the side
of freezer. I had to take two pieces and put them together so the lapped
over on another to make a lip to go against the freezer and also to go out
and around the window. I am sure you can figure it out just play with two
short pieces of angle iron a inch long. I then welded them together when I
got them to the thickness as the window and then drill holes in them to
attach them to the cabinet to hold the window into place. I used self
tapping screws so I could replace the window if need be. I also silicone
caulked the edge of the opening around the hole for the window before
putting it on.
I cut a whole for a piece of PVC pipe to go into so my dust collector can
be attached on to it
TA DA!!!!!!!!!!! you now have a "Cheap" well built " Professional Looking "
Blast Cabinet.
If you need any more info just drop me a line and I'd be more than willing
to help if I can.....................Good Luck Fred
37 Chevy 1/2 Ton
86 Chevy Blazer
98 Drudge 24 valve Cummins
One worn out Timberjack
