| | | Forums66 Topics128,057 Posts1,055,808 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 9 New Guy | | New Guy Joined: May 2015 Posts: 9 | I have a 1949 3100 basket case with a 216. I have purchased from a 1954 3100 a high pressure 235, drive train and axles. I am in the process of ordering rear engine mounts and see there is a different rear engine mount style between units up to 1953 and those 1954 and later.
The different mounts are they related to the frame (1949) or the drive train (1954)?
Thanks for your input. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The rear crossmember and bellhousing mounts are different. Use the '49 bellhousing and mounts and you will have no problems. | | | | | Joined: May 2015 Posts: 9 New Guy | | New Guy Joined: May 2015 Posts: 9 | | | |
