| | | Forums66 Topics128,088 Posts1,056,002 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 47 1949 Beast | | 1949 Beast Joined: Jul 2013 Posts: 47 | 49 chevy 3600 with a54 chevy engine. 6 volt system. Everything was working perfect until a generator went bad. Replaced the gen and polarized it before starting the engine. I am getting six volts at the battery and at the regulator. If I take a volt meter and ground it and touch the gen I get nothing. Take the same volt meter and ground it and touch the lead at the regulator I get six volts. Wiring new, grounds good, replaced all fuses but I cannot get a reading at the gen. Second generator as I thought the first one was defective | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mark,
Are the leads/posts/connectors on the voltage regulator labelled (what are the labels)?
What line/lead is connected to each connector on the voltage regulator? | | |
