1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Having trouble trying to get the glove box to latch. In the FAM sect. 1 14.01-14.02 it shows the latch with center pointed up, mine it tucked under to form a pocket. Does any one have a picture, side view, or at least a picture so I can figure out what is going on. I had it latched once but had to reach up behind it to unlatch it. It was also about a 1/2 inch gap at the top so you could inside the box. 53 3100 root | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | The pictures looked great. Looks like its a 90 deg off the spot weld on the door then the next bend looks like a 45 deg bend. Will have to figure out how to clamp everything before I bend things so no breakage. thanks DADS50 and jockbolters50 root | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Bent, per the pictures, and still will not close all the way. I am leaving it for now, will come back later. root | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | You should not have to bend the lock or latch
do you have a pic? | | |
