5 members (GMCJammer51, DuckRancher, Peggy M, 49nut, 1 invisible), 118 guests, and 1 robot.
Topics128,110
Posts1,056,245
Members48,437
#1112066 07/06/2015 4:13 AM
I'm looking to find the stock axel width on a 55 first series 3100. I have seen a few different measurements floating around but nothing to definitive. I measured about 62" from middle of one tire to middle of the other.
I have an opportunity to buy a ford 9" that measures 58" from backing plate to backing plate and I'm wondering if the difference can be offset with spacers or anything like that, or if I should pass on a great deal and find one a little wider.
Any help would be greatly appreciated
Last edited by Danthemanmj23; 07/06/2015 4:17 AM. Reason: Added measurement clarity
1955.1 Chevy 5 window 3100
Instagram - @1955.1chevy
Crusing in the Passing Lane
Most consistent way to measure rear ends(trucks and cars, that is) is from wheel mounting surface to wheel mounting surface; wheels and tires vary all over.
Can't find axle housing length.
But here is left and right axle shaft OL overall length.
51-57 1/2 ton, left.....29 5/8"
51-57 1/2 ton, right...30 5/8"
..........................+60 1/4"
Source 1929 - 1957 Chevrolet Master Parts & Accessories Catalog Group number 5.420
Looks like all 1951-57 1/2 ton axle housings were the same length. They all used the same length axle shafts.
