| | | Forums66 Topics128,089 Posts1,055,991 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Hello,
I am in the process of trying to rebuild the stock rear end of my 1949 chevy 1/2 ton truck (torque tube style) and I have a question on the pinion installation.
When installing the pinion it states to tap it into place with the J-4050 tool between the pinion and the single row bearing. The next step is to install and tighten the three set screws to 26-30 ft lbs and tighten the lock nuts.
Do I remove the J-4050 spacer tool before I tighten the three set screws or after I tighten the three set screws?
I tried to remove the tool after installing the three set screws and could not remove the tool. I had to loosen the set screws to remove the tool and then re-tighten them.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You remove the tool before tightening the set screws.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | | | |
