1 members (Woodcmiami), 86 guests, and 4 robots.
Topics128,100
Posts1,056,513
Members48,448
#1110750 06/29/2015 2:22 PM
Neverdone
Unregistered
Neverdone
Unregistered
Hello ,
Would anyone have a picture / drawing of the rear bumper area of a one ton panel [ mine is a 53]
I am looking to see the correlation between the bumper and splash guard/ filler . Are they even at the top with the rubber filling the gap between the two ? If so what is the spacing ?
HERE I have the rear bumper secured with the 2 front bolts and up on jack stands before I cut the lower filler panel HERE so the bumper brackets can move up
Any advise as to how it is supposed to look is appreciated . The best pictures I could take ...
Dan
I'd be glad to take a pic of my 50-51 one ton but mine does not have a splash guard/filler.
Let me know
..."some gave all, KIA"...
Haunting the SBP since 2001
I would make sure that you actually have the 1 ton panel van rear bumper brackets on your truck before I started hacking on anything.
The 1 ton panel van rear bumper brackets are specific to those models only.
You will never get everything to line up properly without the correct brackets.
{No other brackets from any 47-55.1 truck will work on the 1 ton panels}.
Neverdone
Unregistered
Neverdone
Unregistered
Let me know
Thanks for the pictures Robert , they clarified a lot and showed I did have the correct bumper mounts that simplex mentioned
