7 members (Lightholder's Dad, Wickedbass, Christian, NJC, Hotrod Lincoln, baldeagle, 1955 1 Series),
59
Mod | | | Forums66 Topics128,017 Posts1,055,338 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | Can anyone recommend a good shop in the southern New Hampshire area ? I need to have the cab corners, lower hinge pockets and in side steps replaced. I have all the parts and have removed the bed and front clip. All the parts are dismantled and need to be primed and painted.
Clem 59 Chevy 3600 New Hampshire
| | | | | Joined: Mar 2003 Posts: 30 Junior Member | | Junior Member Joined: Mar 2003 Posts: 30 | if you put youre mail address in your profile i will send you to a perfectionest.takes time but work is top notch  | | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | My e-mail address is in my profile.
| | | | | Joined: Jun 2000 Posts: 52 Member | | Member Joined: Jun 2000 Posts: 52 | STAY AWAY FROM ANYONE NAMED TONY LAMBERT...used to have a shop called 'Country Gentleman Auto Restorations'. LIED, CHEATED AND PRACTICALLY STOLE from me re a restoration on a 70 442 convertible. Long story. Very ugly. Spent over $5000 on the car AFTER it was done fixing things that hadn't been done right....couldn't even get the stripes the same width all the way down the side of the car. Shop long ago closed, but I'm sure he's around somewhere. | | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | Thanks I'll remenber that name. Those guys all ways find away to popup somewhere.
| | | | | Joined: Mar 2003 Posts: 30 Junior Member | | Junior Member Joined: Mar 2003 Posts: 30 | clem, now i found your email if you didnt get it let me know. good luck with your cab  | | |
