6 members (Jon G, klhansen, dt235sd, Tim Canfield, Oswald, 1 invisible), 92 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#1112004 07/05/2015 9:59 PM
Having trouble trying to get the glove box to latch. In the FAM sect. 1 14.01-14.02 it shows the latch with center pointed up, mine it tucked under to form a pocket. Does any one have a picture, side view, or at least a picture so I can figure out what is going on. I had it latched once but had to reach up behind it to unlatch it. It was also about a 1/2 inch gap at the top so you could inside the box. 53 3100 root
root #1112006 07/05/2015 10:32 PM
root #1112195 07/06/2015 11:41 PM
The pictures looked great. Looks like its a 90 deg off the spot weld on the door then the next bend looks like a 45 deg bend. Will have to figure out how to clamp everything before I bend things so no breakage. thanks DADS50 and jockbolters50 root
root #1112704 07/09/2015 5:41 PM
Bent, per the pictures, and still will not close all the way. I am leaving it for now, will come back later. root
root #1112708 07/09/2015 6:02 PM
You should not have to bend the lock or latch
do you have a pic?
Moderated by  ndkid275, Phak1
