| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I was changing the points on my 38 216 when the phenolic block that holds the stud for the points connection, disintegrated. I managed to adapt a block from a later distributor to get on the road again. The new block has a recessed round nut on the outside with a slot on each side. I used a small screwdriver to tighten it.
Is there a special tool for this kind of nut? Also, does anyone supply these little insulating blocks for the distributor? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Try this tractor supply link | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Dads50, wow, thank you so much. I am going to try one and see how it works out. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | One similar to that came on a rebuild distributor I purchased. ...pic... I hope it works, you won't need that special fork tool. Let us know | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Those funny screwdriverish looking tools can still be bought.
The old time auto parts store loaned me one of theirs said I will like it so much I will want to buy one. I said this looks familiar to me.
When I got home I went into the museum, my dad's tool box where I keep his oldest tools. There in his tool box was three of them.
Next time I went back to the parts store I said thank you for loaning me the tool for just in case. Though would you like to buy some of them from me for my dad has three. We both had a laugh.
Though that link from DADS50 is great for it appears no special tool is needed. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Snap-On sold a Delco distributor tool that had an 11/32" nut driver on one end, and the 2-pronged spanner on the other, back in the 50's and 60's. Just about everybody at our shop except former Ford dealer mechanics had one. I think I've still got a couple of them stashed away in Dad's old tool box.
The shade tree method was to grind a narrow slot in a straight-blade screwdriver to straddle the stud. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | This is the perfect project for someone with a 3D printer. Both pieces couldn't be that hard to make.
I have always so far anyway been able to get that round nut off with a small screwdriver. PB Blaster then BUUUM! | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | This is the perfect project for someone with a lathe. A piece of Teflon, a couple of drill bits, a sharp cutting tool and 15 minutes- - - -no programming- - -problem solved. No need to get high tech! Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I ordered a couple from Steiner in that link. I thought that was the only one they sell for the Delco and that I would file it down to fit the .310 hole in mine. As soon as I ordered it showed me another option which is the exact part for the 54 with the keyway on the shaft. I am trying to have the order changed at the moment. For interest, the more correct part is #ABC500 Square Shoulder type. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Whaaaaatttt, No fertilizer,Jerry? LMAO,gotta have fertilizer on that steady rest for the TIP of the Tool! regards, steve sr. | | |
