3 members (Peggy M, Joe H, Wayne67vert), 52 guests, and 2 robots.
Topics128,026
Posts1,055,402
Members48,422
#1111926 07/05/2015 2:14 PM
I was changing the points on my 38 216 when the phenolic block that holds the stud for the points connection, disintegrated. I managed to adapt a block from a later distributor to get on the road again. The new block has a recessed round nut on the outside with a slot on each side. I used a small screwdriver to tighten it.
Is there a special tool for this kind of nut? Also, does anyone supply these little insulating blocks for the distributor?
1951 1 Ton Completed
Try this tractor supply
link
Dads50,
wow, thank you so much. I am going to try one and see how it works out.
One similar to that came on a rebuild distributor I purchased.
...pic...
I hope it works, you won't need that special fork tool.
Let us know
Those funny screwdriverish looking tools can still be bought.
The old time auto parts store loaned me one of theirs said I will like it so much I will want to buy one. I said this looks familiar to me.
When I got home I went into the museum, my dad's tool box where I keep his oldest tools. There in his tool box was three of them.
Next time I went back to the parts store I said thank you for loaning me the tool for just in case. Though would you like to buy some of them from me for my dad has three. We both had a laugh.
Though that link from DADS50 is great for it appears no special tool is needed.
Snap-On sold a Delco distributor tool that had an 11/32" nut driver on one end, and the 2-pronged spanner on the other, back in the 50's and 60's. Just about everybody at our shop except former Ford dealer mechanics had one. I think I've still got a couple of them stashed away in Dad's old tool box.
The shade tree method was to grind a narrow slot in a straight-blade screwdriver to straddle the stud.
Gas Pumper
Gas Pumper
This is the perfect project for someone with a 3D printer. Both pieces couldn't be that hard to make.
I have always so far anyway been able to get that round nut off with a small screwdriver. PB Blaster then BUUUM!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
This is the perfect project for someone with a lathe. A piece of Teflon, a couple of drill bits, a sharp cutting tool and 15 minutes- - - -no programming- - -problem solved. No need to get high tech!
I ordered a couple from Steiner in that link. I thought that was the only one they sell for the Delco and that I would file it down to fit the .310 hole in mine. As soon as I ordered it showed me another option which is the exact part for the 54 with the keyway on the shaft. I am trying to have the order changed at the moment. For interest, the more correct part is #ABC500 Square Shoulder type.
Gas Pumper
Gas Pumper
Deve
The Think Tank
Whaaaaatttt,
No fertilizer,Jerry?
LMAO,gotta have fertilizer on that steady rest for the TIP of the Tool!
regards,
steve sr.
