| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | Stupid southwest pot hole. Hit one I couldn't avoide in my 59 and it broke the passenger front shock mount on the frame. Does anyone make them? Figure the drivers side needs replaced as well since its only a matter of time. Thanks for any help you can offer. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I'm not familiar with the '59 but my old '84 Silverado had a frame made from bubble gum wrappers. I kept blowing out upper shock mounts. The local weld shop had huge flat washers about 4" across & 3/16" thick that they'd weld to the frame and run the upper shock mounting bolt through that. That may or may not apply in your case but it's worth mentioning.
