2 members (TooMany2count, J Lucas), 33 guests, and 2 robots.
Topics128,036
Posts1,055,450
Members48,422
#111162 08/13/2004 3:55 PM
I'm finishing up the body work on my 49 1/2 ton before it goes to the paint shop. I need to finish door jams, inside of doors, etc. Painter will only be doing exterior. It would be much easier to do my part with the doors off. I'm thinking about removing them at the hinge points on the door since that only affects fore and aft adjustment when they go back on. Am I getting ready to do something that I will regret? i.e. getting the doors adjusted properly without an enormous amount of work.
#111163 08/13/2004 5:14 PM
I would take them off. Yes you will probably have fun adjusting the doors when you put them back on but it will look alot nicer if you finish the jams with them off. Just my $0.00002 worth.
Joe K.
1963 Chevy Stepside
350 with 3 on the tree.
1960 Chevy Bel Air
35k original miles
1991 GMC Syclone #1557
1992 GMC Typhoon #0261
#111164 08/13/2004 11:24 PM
If you drill a small hole all the way through the hinge and the body (or door) before you take it off you can use the drill bit as an alignment tool when you go to put it back on. It is very easy that way.
Paint & Body Shop moderator
