2 members (Gray_Ghost, 1 invisible),
179
Mod | | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 113 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 113 | Now that I can drive and stop my 59 8503 it is very obvious that the steering is terrible. I have about a third of a turn of the steering wheel of play. The culprit seems to be a worn out drag link. I have been in touch with obsolete Chevy and Jim carter but no one has a match. Anyone know of a source? What about the part number. I thought it was 3729928. But that does not seem to be it. I could not find a number on the one on my truck.
1959 Chevy 8500 - Spartan 80 366 BBC
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Gene_Spartan80, the p/n for the "drag link" (rod, steering connecting) is 3724799, that is for standard steering which I'm assuming you have, hope that helps. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I will add that the rod is 17-5/16" long and was used from 56-59 on 8000 & 10000 Series trucks. Mike B  | | | | | Joined: Apr 2015 Posts: 113 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 113 | Mike B, Is that length the length from center to center or overall length?
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Overall Length... Mike B  | | |
