9 members (carbking, Mike B, klhansen, Youngin' Tut 59, Pete1946, Gray_Ghost, BarryP, dt235sd, 1 invisible), 89 guests, and 3 robots.
Topics128,139
Posts1,056,758
Members48,454
sorry guys I tried search,no luck.are the out put shafts enter changeable 3 speed to 4 speed?.
This site covers trucks from the '20s to the '70s. There were several transmissions used during that period.
you are so right cletis.i should have had been more spific.the 4 speed is sm420 out of 66 chev long bed,the 3speed is referred to,as mk1.used in 60s&70s cheverlets car &panels. atleast that is where I got mine,1955chev panel.thank everone..
If you are asking if the output shafts are the same part on the
3 and 4 speed transmissions, I'm sure they are not. If you are
asking if the spline is the same I'm sure they are.
DG
Denny G
Sandwich, IL
