1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | I bought an OEM tire rack (actually wound up with two of them) but all three studs do not line up with the holes in the spare wheel (8 lug pattern) - only two line up. The third goes through the center hole. Is there a difference between tire racks for 6 lug C10 and 8 lug C20 trucks? Thanks.
1965 Chevy C20 Stepside
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Don't see how 6 on 5.5 could possibly fit 8 on 6.5. There is a 1/2 T and a 3/4 T holder.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | I see what you mean. What are the 5.5 and 6.5 measurements?
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I see what you mean. What are the 5.5 and 6.5 measurements? A 6 lug wheel is designed for 6 wheel studs on a 5-1/2" Bolt Circle A 8 lug wheel is designed for 8 wheel studs on a 6-1/2" Bolt Circle They are measured as follows: http://i645.photobucket.com/albums/...alculators/Bolt%20Circle_zpsw8ogsqqt.jpg Should be simple enough to make an adapter. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If you want, you can sell your two 1/2 T for about the price of one 3/4 T (Ebay prices).
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Thank you for your help as usual John and thank you too "Bartamos". I have not seen a 3/4 ton rack for sale and did not even know there was such an animal until you posted.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There are two or three right now on Ebay. Good luck.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | I have seen some on Ebay but they are all for 6 lug wheels - I asked to make sure. Can you tell me how they are listed or send me a link. Thanks alot.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Search 60-66 3/4 spare or 60-66 3600 spare or 60-66 c20 spare and all those using individual years I.E. 1960 3/4 spare then 1961, etc. This one is sold, click on "see original listing" and scroll down if you want to read that it says "3/4 Ton 8 lug bolt". It is listed as 55-66. Found this under "completed listings". I was not searching to buy just searching for you to be sure there are two types. http://www.ebay.com/itm/55-66-Chevr...53289631?hash=item19ff0dfe9f&vxp=mtrAnother sold one: http://www.ebay.com/itm/55-66-Chevr...81671214?hash=item3cf95d2e2e&vxp=mtrJust keep checking. They seem to all sell. You really do need to put a wanted in Stovebolt. That's what it's for. AS HAS BEEN MENTIONED: It would be fairly easy to modify your plate, make a new plate or fab an adaptor plate. Wheel studs are cheap and very, very easy to install. Maybe you have enough room on the plate to locate that third stud after removing the misaligned one. No one will see the mod behind the tire. http://www.oreillyauto.com/site/c/s...t&model=C10+Panel+RWD&vi=1442230
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Thank you for all your help and information. I will put an ad on Stovebolt. I have considered adapting one of the ones I have as well. I don't think there is enough room on the plate to move the stud but I could make a larger plate as you suggest. My only question about that is if the 3/4 ton rack is any bigger or different in any other way to hold a possibly heavier wheel (I am probably over-thinking the issue).
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If you have time and patients, you can sell yours and buy the correct one now that you know there is a difference and see that they are available sometimes on Ebay and hopefully elsewhere. I would have to admit that fabrication, in this case, would be for parts that are not available anywhere. Otherwise having the correct donor part is always preferable. Also no use ruining a good saleable donor part you have.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | That is how I see it too. I would rather have the correct part if possible. I will continue my search.
| | | | | Joined: Jul 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 43 | Sent you a message in the swap meet section. I might have what you want. Janine | | |
