7 members (Bill Hanlon, Otto Skorzeny, 52Carl, Hotrod Lincoln, TooMany2count, chemanic, 1 invisible), 92 guests, and 2 robots.
Topics128,135
Posts1,056,418
Members48,441
Apprentice
Apprentice
Hello,
I've searched this site for 2 days looking for a reference to the following but have not found anything - if this question has been answered b4 I would appreciate being pushed to the appropriate forum / articles.
I have a 1950 Chev 1314 (Canadian model) that I purchased as an occasional driver 5 years ago and am just now getting the time to work on - upgrade / restore. Before me it's had at least 4 different owners - all of whom contributed to re-building the unit. As a result it's got a 235 ci engine (serial no GM 376576 - which I think makes it a 58-62 Chev) coupled to a 4 speed transmission that I cannot identify. First gear in this transmission is very low - which means it's rarely used. I was under the truck 2 days ago to replace the Brake master cylinder - which brought me face to face with the transmission - lo and behold it's got a PTO! (not hooked up to anything - but it looks like it'd be cable operated to engage / disengage.)The output shaft has a "brake drum" attached - this is in turn surrounded by a Brake mechanism which is not hooked up to anything - the truck has rear parking brakes operated by a foot pedal, which looks stock, and cables running from a mid-frame cross-shaft. I scrapped 50 years of accumulated grease and grime off the body of the transmission and here's what I found on the driver's side (reading from the top down)
J 317
GM
5591953
On the output end under the "brake drum" the following is cast:
D (or it could be "b") * 2 -so that'd read D*2
3845106
The housing containing the PTO is painted yellow - rest of transmission is bare metal - and has two, 3 inch long diamonds cast into it - there are some characters inside the diamonds but I cannot decipher them - too fine a casting.
I swear that this transmission housing is cast from porous metal as it oozes lubricant from everywhere! I've had an oil pan under it since I've owned it and I NEVER park it in friends' driveways.
I would really appreciate advice as to:
- what kind of transmission this might be
- is the PTO an option that I can remove - I'd need a plate to cover the opening - I'd like to remove it as it interferes with brake line routing for new dual chamber master cylinder that I'm installing
- are parts available for the transmission ?
- is there a sealant that I can "paint" the interior of the housing with? I'm not kidding when I say that it oozes lubricant.
thanks in advance for your patience - and hopefully answers
Junior Member
Junior Member
Sounds like you have the original type trans in this truck. They were used in the bigger trucks like the 3/4, 1, and 2 tons etc. That PTO is a bolt on. The transmissions all had the opening for with a cover for it from the factory. Some of the pto's had forward and reverse. It is not a "rare" item but is a little unusual to see one on a pickup. If reverse is over to the left it is the correct vintage for the pickup you have.
Apprentice
Apprentice
Thanks for quick response !
yup - Reverse is to the left and back
Prairie Sailer,, Welcome to the Stovebolt cool
It sounds like it is an SM-420 trans out of a 2-ton or larger truck with the park brake on the rear of the trans.
The SM-420 trans were used from the 1/2 ton pickup and up into some of the lighter big trucks.
I just did a little researching on your 4 speed. The #3845106 is one number off that I am showing, my manual is showing #3845107.I don't know if this would be close enough or not? If so here are your trucks. 55-59 1 ton /4 speed.(2nd Ser.) 59 1 1/2 ton w/4 speed 60 Ser. 10 thru 40 w 4 SPD. 61-62 Ser. 20 thru40 w/4Spd.(exc.4 WD) (use with /8x21/2 inch prop. shaft brake. Also 55-59 3/4 ton w /4 spd. (2nd Ser.) :p
Apprentice
Apprentice
smile
Thanks to all for timely and helpful responses. I appreciate the help.
