| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | I disassembled my engine for rebuilding and removed the oil pump mount from the block,some people say the block is now no good,since it was factory aligned.but I also talked to a local rebuild shop that also removed this adapter while rebuilding a 261, it's been running since 2003, your thoughts?
1962 GMC 920 step side 261 4 spd
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I have not worked much on these engines. Though I can not visualize how you would of harmed your engine. Though I an sure those in the know will respond. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | As long as you use the original shouldered bolts you will be okay. I would put the oil pump and distributor in place while tightening the shouldered bolts to make sure everything is lined up. I have needed to do this in the past and it is still working fine. To reuse the original bolts grind six sides in the head to except a socket.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | It's also possible to drill a hole in the bolt head and use a cutoff Allen wrench and a BFH to form a six-sided socket. Use a Vise Grip to hold the Allen wrench and form the hex with one hard blow. A 1/4" drill bit and the same size hex wrench should work about right. I'd suggest machining a close-fitting alignment shaft that fits the block and the oil pump mount to keep it in place while re-bolting it. Jerry
| | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | Thanks guys ,spent some time worrying about this,I did think about each of those ideas, machining a shaft to fit , and also assembling the distributor,oil pump and adapter,but also installing the cam and giving it a spin to align things up.the block is in the machine shop getting a sleeve,due to catastrophic piston failure.this is my first old engine I've been in to,I am a HD diesel mechanic and I thought this would be easy. There will be no rushing this repair.
