8 members (68ironhead, jmoore, Joe H, Phak1, 55shaker, 3B, Waveski, 1 invisible), 74 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
Junior Member
Junior Member
I have a 1941 the running boards after sand blasting are badly pitted and in some cases small pin holes what is the best method for repair. some one had suggested use lead because bodt filler would just pop off. thanks in advance. :confused:
41 1/2 ton
don't force it get a bigger hammer
use jb weld fill each spot and put a peace of masking tape over the area to flaten it and until it hardens remove when dry and sand jb weld is very permenent heat wont hurt it trust me it will work and its fairly cheap if its a bigger hole put tape on the back side first
