| | | Forums66 Topics128,162 Posts1,057,049 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | Hello.
On the immediate backside of the 1955 235 exhaust manifold, there is a fitting for a vacuum line.
Can someone please tell me where that line connects to and what is for? I am hooking it up in my 1941.
Thank you.
Judson | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I think what your seeing is the tube for the hot air choke possibly. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | First you must be talking about the intake manifold. Are you sure it is a 1955 manifold? The only vacuum port on a 1955 intake should be on the side in the center, circled in this link.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | It's where the vac wipers are connected if its the one Dave is talking about. | | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | Yes. Its the one in the pic that Dave linked. Sorry for the confusion. Im pretty sure its a 55 manifold, but it has dual exhaust and carb so Im pretty certain its not stock. But it still has that vacuum hookup in the same place as the pic.
So its a straight shot from there to the wiper mechanism?
| | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 |
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | great. thank you. any problem you can see if I just cap it until I get the wipers hooked up? | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Just cap it till ready to use it. No Problem. If You don,t You,ll have a bad vacuum leak! regards, steve sr.
| | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | | | |
