2 members (Guitplayer, Achipmunk), 61 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
MFW
Offline
I am currently installing a 12 volt conversion on my 54 and I can't figure out what post on the ignition switch. The instructions say "IGN" but I crawled underneath and couldn't find markings. I traced the wires to radio, the other post had the heater switch attached to it and the other went to the firewall.
Also, what's the light for?
Thanks matt
1950 GMC 100
1954 GMC 470
1954 Chevy 3100 Hydramatic
More pix on Flickr
1957 Ford 850 Tractor (video)
...click...
The light illuminates the perimeter of ignition.
MFW
Offline
So the wire I need to connect is coming off of the da plug on the alternator. I have the 3 prongs like the diagram provided. Still confused on which prong to connect it to?
Sorry I am new to this...
Matt
1950 GMC 100
1954 GMC 470
More pix on Flickr
Sir Searchalot
Sir Searchalot
Need more info. Foot stomp start? Trying to use original switch?
Crawl underneath? Pull switch from dash and let hang to see and wire it.
Check the Tip Section here on Stovebolt, here is one:
http://www.stovebolt.com/techtips/12_volt_conversion.html
If you are unsure about switch, take it to bench and do a continuity test to see OFF ON (ACC.), IGN is "ON" position with a foot start.
MFW
Offline
Not a foot starter. It has the button on the dash above the lights. I am using the original keg switch.
I crawled in between the seat and the pedals and pulled the ignition out and couldn't locate any initials near the prongs.
Matt
1950 GMC 100
1954 GMC 470
More pix on Flickr
Sir Searchalot
Sir Searchalot
I assume you have read the alternator part of the link I posted.
If there are no terminal markings on back of switch, then just test the switch with a light or meter to see how it works. It is basically sending hot to coil when key is rotated CW.
The original hook up: red wire from voltage reg (batt) to one Ignition switch terminal. The other terminal was wired to coil + and to gas gauge. The push button was wired across the solenoid. http://chevy.oldcarmanualproject.com/electrical/wiring/pdf/54truck.pdf
This is all general info. Don't know what all you have done or what components you have. I think you may be running into, the dreaded, PO wiring.
MFW
Offline
I am guessing that you are right about the previous owner. It's a mixture of new wiring and old wiring. I will use my test light and figure out which terminal only lights when the key is on and hook it up to that one.
Matt
1950 GMC 100
1954 GMC 470
More pix on Flickr
