So as in a previous post I have the 4 wheel disc set up from a p30 or chevy 3500 (1996 era)
I scouted a hydroboost out of a 2001 GMC Savana 3500.
GM part 15192190.
http://www.discountoeparts.com/gmc/...-engine/brakes-cat/hydraulic-system-scat
Would this be correct in using this part. I will also use the power steering pump that comes with it although I have no power steering.
or
Also is there a 12v v alternator with a pump attached as one unit that would work in this application . Part #?
Chris
Thanks much for your input
