0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | 1946 2 ton 4 speed.
Would the truck having a power take off, I assume that is what that is called because the rack body truck has a lift bed, would cause the transmission to need more transmission gear oil to fill it up? | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Q. Does 1946 2 ton 4 speed have PTO "Power take-off" ? A. Yes Q. Would lift bed, cause the transmission to need more transmission gear oil to fill it up? A. No 1946 Chevrolet truck transmission Specifications page On bottom of page, left column, it says "Power take-off" Look to the right, 4th column, which is the 2 ton, 4 speed tranny, Power take off left side. Bottom row says 5 1/2 pints lubrication capacity. Lift bed hydraulics has its own separate fluid system. What series number is your 2 ton truck? | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | We do not know the exact series number. Though being it has a 160" WB it and 2 ton that it is a 6400.
And we just put in 5 1/2 pints in. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | We do not know the exact series number. Though being it has a 160" WB it and 2 ton that it is a 6400. Is there a vehicle id plate on the truck? If you have the stamped number on the plate or on the title you can enter in The VIN BusterIt should give you the series info. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Is there a vehicle id plate on the truck? If you have the stamped number on the plate or on the title you can enter in The VIN BusterIt should give you the series info. Been to vin buster before and it does not say which 6400 it is. It can be a 6402, 6403, 6408, 6409, 6412, 6418, 6419, 6422, 6429, 6432 | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | jorb, Reread the 1st post, He,s asking if the TRANS needs more gear oil cause of the Added PTO. Has Nothing to do with the Hydraulics of the lift/hoist mechanism and quantity of oil. regards, steve sr. P.S. in that regard,Im gonna hazard a guess at about a 1/2 pint to get it to the side plug in a SM Box. wink | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | jorb, Reread the 1st post, He,s asking if the TRANS needs more gear oil cause of the Added PTO. Has Nothing to do with the Hydraulics of the lift/hoist mechanism and quantity of oil. regards, steve sr. P.S. in that regard,Im gonna hazard a guess at about a 1/2 pint to get it to the side plug in a SM Box. wink Yes this is what I was asking. Thank you for re-writing it better. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | According to the 1946 Chevrolet truck transmission Specifications page it looks like All 1946 4 speed transmissions came with PTO. The spec sheet does not indicate a lubrication capacity, for a 4 speed transmission without PTO. So, if a person wanted find out the difference in lubrication capacity between a tranny with PTO and a one without. You would have to find a tranny without PTO and fill it up and measure the difference. Or, In 46 they offered 2, 4 speed trannys, one with PTO and one without, and there is no difference in lubrication capacities between the 2. Or, 5 1/2 pints is sufficient for both. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Oh Boy, Put the Recommended amount in the box. Stick finger in hole. Can you touch oil? If not, ADD till Just Below Fill Plug, Good to GO! regards, steve sr. | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Thank you Steve, I can stop banging my head now. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Thank you Steve, I can stop banging my head now. Yeah, now I will sleep better at night too. It really doesn't matter what level you choose to fill the transmission as all of the overflow will run out of the front main shaft housing weep hole...onto your clutch. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Paul, I understand what You are sayin about the oil levels, Especially the older boxes that have no front seal. Thats why I ALWAYS Went with the oldtimers rule of thumb (or pinky joint) Filling gearboxes. Leave It Just below the fill plug and it Don,t Leak on the clutch. And were talkin HARD Working Tow Trucks and Flatbeds out there chasin wrecks and whatever. To add... I,ve NEVER had a trans failure due to lack of lube in over 40 Years. Stupid operators are another story,or is that"steering wheel holder" LOL steve sr.
