1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
Stovebolt Photo Moderator
Hello gang,
I de-greased the flat area next to my distributor and uncovered a code that looks to read "AFCA685099" I've checked our site and a few others and come up with no info. It's a 47 truck (3800 Thriftmaster) but I do not believe the engine is original. Any help would be appreciated. The markings look to be good hits but, hey, maybe I'm reading something wrong. I'll try a photo but my lighting isn't too good.
I imagine it's a 216, but there are slightly different casting identifiers than my confirmed 47 216 on another truck. By that I mean, on the drivers side where the throttle linkage attaches there are 2 additional holes that look like they may accept a bolted attachment of some kind, directly above the generator bracket.
Also, the floor directly behind the bellhousing is cut to accomodate the bellhousing. Oddly, the SM420 lands perfectly in the floor board hole. Perplexing to me.
Thanks folks - Joe
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
Sounds like the side engine mount casting found on later vintage 235's.
Lots more pictures
Joe,
How tall is the lifter cover?
Does it go from the edge by the distributor boss all the way to the bottom of the rocker cover?
Or does it only go up to the joint between the head and block?
steve sr.
Steve - The lifter cover goes from the bottom of the block right to the underside of the valve cover. I has 6 holes for the spark plugs.
Tim - your catalog reference about sums it up. Looks to BE A 216 FROM A 48 and it makes sense. This is a 3800.
Bond Villain
Bond Villain
Joe -- FWIW -- The reference I told you about yesterday concurs with Tim's.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
