0 members (), 100 guests, and 3 robots.
Topics128,194
Posts1,057,261
Members48,466
#1110183 06/25/2015 11:10 PM
Moderated
Moderated
Hello Everyone!
Does anyone know where I can get the bushings to increase my hub size from 4.75" to 5.25"? I have a 54 1.5 ton with the smaller hub size and 6 extra rims that have 5.25" centers. I am also looking for the clamp plates mentioned in the wheel tech tip. I've tried looking googling but have come up empty. Thanks in advance.
1954 Chevy 4400
The bushings you'll have to have made to suit.
The clamp plates you'll find used on most of these old trucks. Not sure people give them enough thought to try and sell them, bet a lot go to scrap.
•1952 Chevrolet 3800 pickup
---All pictures---
BigRigE, If you can't find someone locally I can cut some and ship them to you. Probably a 2 week turn around as out laser is super busy at the moment!
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
RDomeck, I sent you PM.
What is the tolerance and finish on the laser cut parts? Front bushings would be nominally 1/4" thick, and rears about 1/2", perhaps a little more if the wheel centers are much more than 1/4" each.
Would they then need truing up to size on a lathe? I think you want a pretty good precise fit, at least I would.
Another option is http://www.warricktubing.com/
I bought a piece of seamless steel tube listed as 4.75" ID and 5.25" OD from them last year along with some stuff for another job. I have not really measured or checked it out to see if close enough fit to just cut off slices of it or if needs a little machine work, or if there is even enough material to machine.. If not then you could buy from them a somewhat oversize tube to turn and bore to what you need. Might be cheaper and I'd think a lot easier than starting with a solid bar or burnt out rings.
Grigg
---All pictures---
Our laser is down to .003" tolerance. It would be easy to burn them a little under/over and lathe them down, but would of course ad to the cost. I can't imagine that .003" would be any less tolerance than the wheels have?
I'll price out making some washers and see what direction would be good to go with.
Randy Domeck
[email protected]
317-258-0039
Moderated
Moderated
Thank you Randy and Grigg.
I'm going to take some exact measurements when I get back to my shop. The truck came with three 20x6.0 rims that are three piece and three 20x4.0 two piece rims. I think the 4.0 wide rims should work with my new 7.50 tires but would like to have options if something were to go wrong down the road.
1954 Chevy 4400
This is an old post, but if anyone else wants to know where to get bushings to increase the hub size from 4.75" to 5.25", try Ebay. Search for 1/4" Steel Ring x 5.25" OD x 4.75" ID, A36 Steel. Lumberjack1983 is selling these rings for $6.60 plus shipping as of this writing.
Crusing in the Passing Lane
Rings also need method to retain to keep from walking out!
Ed
I have had some made that cost a lot more than what they are on eBay. The ones I had made fit pretty tight, but I tacked them to the hub in a couple of places. They really don't want to go anywhere. I just bought 16 of them and the shipping was $8 for 16. That is the same as for one.
