| | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 68 'Bolter | | 'Bolter Joined: Jun 2015 Posts: 68 | Hello, I have just acquired what is supposed to be a 1953 4100. There are lots of conflicting items but those may just be replacements over the years. Truck is in fair condition main areas are cab corners, floorboard, doors and damage in the drivers side cowl area. The wheels are three piece but there is rust blooming where the centers rivet to the rim. It this type of rusting repairable or is the wheel not someplace for repairs? I've been reading the archives, up to page 195 so far Chuck 53 4100 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Rust between the wheel center and rim is quite difficult to remove short of breaking the wheel apart which is not easy at all. Look for some better used wheels is probably best option. Some sand blasting and something like POR15 might do a reasonable job on what you have. I know blasting and Powdercoating won't seal the existing rust in, as I have a few wheels like you describe, thankfully not very bad yet. I am working on a replacement set though.
Grigg | | | | | Joined: Jun 2015 Posts: 68 'Bolter | | 'Bolter Joined: Jun 2015 Posts: 68 | Thanks Don, I am planning to be there.
OK Grigg, I was wondering if this was a "as long as it isn't too severe" item or if it was like the widow makers "never for any reason". I'll start assessing just how bad it is Chuck | | |
