| | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11099 06/28/2002 2:17 AM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Maybe this is a dumb question, but I started doing the brakes on my new 50 1/2 ton and one of the front wheel studs is loose. It had been replaced at one time. It's not sloppy loose,just able to slide it in and out. The drum and hub are in great shape and those Huck drums are hard to find. Is there a fix for this? | | |
#11100 06/28/2002 2:53 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | If you can find a parts store where the y operate on inteligence, you should be able to find a stud with a larger shoulder that will fit tight.
