8 members (Perro, Hush, Lightholder's Dad, John L., Otto Skorzeny, lumbersawyer, FAST55, Hanks custodian),
182
Mod | | | Forums66 Topics128,075 Posts1,056,007 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I am close to installing new door glass U-channel in my 55.1. But I'm not sure just exactly how the U-channel is supposed to be fastened to the door. I know the lower part of the U-channel clips into a U-channel guide. The old U-channel did not have any clips, nor does the new one. Is it time to pull out the hot glue gun and glue the U-channel to the door window opening? | | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | I'm at the same spot with my 55.1 and have my glue gun out. I'll be watching here for others advice.
Thanks, Buddy in AK | | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | On my '51 with '50 doors I placed small screws in replacement channel into door frame at top. (I think like #4x3/8 sheet metal)The door felt channel in the rear of door had a retainer clip that slid in a retangular hole in door channel.Because mine was a one piece window in a metal frame I made a plywood form and preformed the channel before installing. I would go with black weatherstrip glue. It fits fairly tight and I'm sure this would hold I beleive the 55-1st had a 2 peice channel one in wing frame and one for top & rear Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
