5 members (2-Ton, Otto Skorzeny, TUTS 59, KEVINSKI, Fannin), 155 guests, and 2 robots.
Topics128,084
Posts1,056,085
Members48,434
#110981 09/10/2002 5:12 AM
I have had this little spot sand blaster for a few years. I have to say, it is one of those tools that I can't see how I lived without it. I have sand blasted everything from little dime sized spots to a complete set of wheels. In fact, I started using a new pressurized blaster I had got at Harbor Freight and put it way after finding this little blaster worked better, even for the big stuff.
The sand catcher has a few rubber tips that you put up against the surface. When you pull the trigger the sand hits the surface stripping the rust/paint and then it is caught in the bag. I can't tell you enough how well this thing works. You could spot blast the dash board in a restored car without getting ANY sand anywhere! The rubber tip on it in the photos is the small round one, there are ones for corners, rectangle, and large round. Truly a great tool for the pro as well as the home hobbyest.
I bought it on a MAC tool truck, but have seen it in a few different catalogs.
If you don't have a MAC truck stoping by for you, just call a few shops in the area and find out when the truck stops by there and wait around for the guy. They are both made by UNITEC in Bedford Hills NY. The Sand blaster is number 007 while the "HOT SPOT" sand catcher is number HS2020.
[img]http://members.aol.com/whatcouldiknow/speedblaster.jpg[/img]
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#110982 09/11/2002 2:56 AM
Martinsr
You need to quit messing around with these posts and just write the book BODY AND PAINT WORK FOR IDIOTS $49.95 at your local book store! God knows I need two copies. LOL
Yor tool post is timely for me as I'm giving up on local jack leg body men after the mess I'm going through with my Buick currently, and buying tools to do it my self. I think with a little practice I can do the same amature work with out the I don't give a d&%* attitude.
#110983 09/11/2002 3:19 AM
I am working on that book, it will come. The blaster AND the "hot spot" catcher can be found at http://www.eastwoodco.com/cgi-bin/sgdynamo.exe?HTNAME=default2.htm
1948 Chevy Pickup
#110984 09/11/2002 2:04 PM
I got a Chinese version from Harbor Freight a few years ago and it is very useful. They do not list it anymore.
Here's another similar product:
http://merchant.cboss.com/ProductDe...&CategoryID=3436&ProductID=10769
Or, if you are a macho boy or girl (sorry, couldn't find a price):
http://www.usatco.com/174.htm
Tim
