7 members (Bill Hanlon, Otto Skorzeny, 52Carl, Hotrod Lincoln, TooMany2count, chemanic, 1 invisible),
96
Mod | | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 |
Today is the best day of my life!!!
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I assume you are referring to the heater switch in the first pic.
The second pic shows an aftermarket starter switch. | | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Thanks for the help and Man, am I NEW to this!!! A heater switch? How did I miss that?
As for the aftermarket starter, how does that work with the stomp starter. I have been using the stomp starter. Should I be using the other one?
And again, thanks for the help. I will do more research first next time.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year truck?
What type of after-market starter?
6v or 12v?
What size/year engine?
What transmission?
What year flywheel is on the engine?
Does your foot-actuated starter not work properly? | | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Truck is a '54 3600 with original 235 engine.
Do not know about transmission or flywheel.
The after market starter was not put in by me. Foot starter works fine. In fact, I tried "after market" starter this morning and nothing... So not sure if that is what it is.
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | The foot pedal part of the starter (that your foot touches, your "stomp starter") is just an offset lever to actuate the starter switch (that is physically located on the top of the starting motor, called "starter"). If you sat in the passenger seat, the starter would be in the vicinity of under your left foot. The starter switch is connected to the battery- hopefully by a large cable; once it is depressed (by that foot action & extended lever), the starter switch contacts make an electrical connection causing the starter to come to life; the lever on the starter also makes a gear extend into the bell housing, engage the flywheel ring gear, & turn the engine. Here's a starter switch that goes on a foot-actuated starter. You can see the underside & the contacts I was trying to describe. Adjectives made all this really confusing for me at first, so I hope this helps clarify some things. Remember, some things may also be in the truck that are not wired to function right now, or bypassed ; the push button "aftermarket starter switch" dangling from the dash could also be wired up to do any number of things- so I'd follow the wires to see where they went before I kept on switching it on/off. Brad Wrench Fetcher, PhD | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If the push button was used as a starter switch at one time truck would have had an electrical solenoid starter not a foot actuated starter. It does look like you have a mechanical foot starter. Can you follow the wires on that push button switch and determine what it is or was wired to? Can you state if you have a mechanical or electrical solenoid. Sorry, I now see that Brad was answering as I was typing. Same gist.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | Maybe some one wired it in as a horn button.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | The foot starter works fine. I am trying to see if anyone knew what the push button hanging down is. Nothing appears to happen when I push it. Guess I will be playing around under the dash this weekend to trace the wires and see where they go.
Cletis: is that an aftermarket or original heater switch? I have not seen one like that before in my searching.
Thanks for the ideas/help.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The button hanging down looks like an add-on push-button (finger-stomp) for an electric solenoid starter. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | You'll have to trace the wires The first switch could be the heater switch as stated before ...pic... Same style switch was used for some fog lights ...pic... | | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Thanks for the heater switch picture. That looks very much like the switch.
How does the heater work then? Thought it had the lever on the heater unit itself.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You need to post a pic of the heater to get an answer on that. There were 2 dealer offered heaters and dozens of aftermarket heaters in 1954. | | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Thanks. I will post a pic. How do you guys know so much!!! I am very impressed and hope to one day have a fraction of the knowledge y'all have!!!
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Everybody starts at zero. Then learns from their Dad, friend, School, job or farm training......or "digging in" to fix the car on Sat and Sun to go to work on Mon. I did that Every weekend!, had no money for a good car or mechanic. No books, no internet. AND some are still learning from the Stovebolt, like you and me.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I learned from a bunch of good old boys who were the mechanics on my brother-in-laws' dirt track race car (and they worked in parts stores or machine shops in their real jobs). | | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Well I am still very impressed with the knowledge on this site. I will try to pay attention and learn from y'all. Here is a picture of the heater: http://s45.photobucket.com/user/serb28/media/DSCN0470.jpg.html
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That is the Recirculating Heater. The lever is a manual adjustment for diverting different % of hot air between windshield defrost vents and the floor. | | |
