2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#1109343 06/21/2015 1:43 PM
What is the best way to remove the bushings for the spring shackles and how to install without beating them to death?
Moderator, Electrical Bay
Sometimes you get lucky and you can use a bolt & nut, the new bushing and a heavy duty washer of the right size diameter to pull the new one in as the old one comes out. Use a socket (size large enough to catch the spring but also large enough for the old bushing to fit in the center of) or a 3/4 threaded pipe connector so the old bushing will have somewhere to go. Get a bolt as large as you can get. Sometimes you can find a bolt whose head is the right size to pull the new bushing in. Please don't try to use a 1/4" or 5/16" bolt. You'll probably need to exert a LOT of pressure if your springs and bushings are original. If this doesn't work, your bushings are stuck and you'll need to use a hydraulic press, maybe a little heat, a lot of prayer, etc. Grease the new bushing to help it go in. Good luck!
Having said all this, please check your threaded bushings before you do anything else. My experience is that these wear much less than the spring eye bolts at the other end of your spring. In fact, I just replaced all 4 springs on my 1952 and none of the shackle bushings needed to be replaced.
Jon
~ Jon
My Blog
Thanks I think I got a handle on it hopefully get done today.
You guys now how to make life easy 10 minute had drivers side done took me longer to get the pieces together than putting in the new bushings. Thanks
Ah..., the things we pick up along the way that make life easier thumbs_up
My Blog
