2 members (Shaffer's1950, 1 invisible),
102
Mod | | | Forums66 Topics128,089 Posts1,056,439 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | About a week ago my 235 in my truck started to run really rough when i would hold the brake pedal hard to the floor. When i would let up and only apply light to med pressure to the pedal it would smooth back out.
By disconnecting the vac line to the booster i confirmed it was the booster for sure. Im currently running the booster vac line from a T fitting on the manifold that has the other end connected to the PCV valve. I see lots of other people do the exact same thing on all kinds of setups to feed the booster so i think im still safe to do it.
As i tilted the booster to get it out about 1/4 cup of engine oil poured from the vac inlet port. Found out after that my booster one way valve was not restricting air from flowing in, thus every time i would release the brakes the booster would suck in air from the t fitting where the combined PCV port was attached. Im a little concerned as to the amt of fluid that accumulated. It could have been pulling fluid for some time now. I think the rubber in the booster finally gave in and developed a hole in a location where it would fail and full travel.
Possibly my PCV is getting splashed where it is installed in the old breather tube location but it still has the oil baffle installed in the crank area. Its got me a bit concerned that im pulling too much oil mist or something.
Any suggestions? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It may be gasoline or brake fluid. The vacuum hose should go up above the booster & come back down. You will notice all original factory units are like this. GM puts a filter in the line. Brake fluid can get in from a leaking master cyl. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | 100% its engine oil and not anything else. My booster is under the floor of the cab. | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | Have you tested the booster check valve. It allows vacuum into the booster when manifold vacuum is high and traps it in when manifold vacuum is low. It's a one way check valve that allows air to flow in only one direction. If it does not trap the low vacuum state then the higher vacuum in the booster can suck oil in.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Yes and I found it was bad. I know that's why the oil is in the booster. It's easier to suck air in that side rather than the opposite fresh air side thru the boot breather holes and filter.
I'm looking for solutions on possibly other things I can do or add to possibly catch the oil if this happens again.
| | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | You could add a vacuum canister into the system, the one I bough from JEGS before had a check valve on its input. It also help smooth the vacuum level stay low a bit longer.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | wolffcub,
What year and size and make Canadian truck?
Does it already have a vacuum tank/canister?
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | I added a tomato can (vacuum canister) to my 59 for added vacuum for my under floor brake booster. I have an extra one that I took off a 60's model Ford truck for sale.
1959 3100 Apache Fleetside
| | | | | Joined: Feb 2004 Posts: 29,828 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,828 | With a little tinkering, a disposable Propane tank for a Coleman stove or lantern makes an excellent vacuum reservoir. It's much thicker than the "tomato can" reservoir and it can be fitted with a drain petcock to remove any oil it might trap. PM me for a sketch of how to do the modification necessary to convert one. Jerry
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Ford used "Tomato cans" for years, light, work well and look cool. When plumbed correctly there should be no oil in can. Should be a dedicated line to manifold vacuum source. As my buddy says about the old vehicles " When you veer from the stock design you become your own engineer". So true, good luck with it.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
