| | | Forums66 Topics128,122 Posts1,056,332 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 43 | I have been smelling gas in the cab of the truck ever since the first time I stopped and filled the truck since getting it running. The fact that the carb leaked like a waterfall at that point led my mind to keep believing that the gas smell was always coming from the carb.
Apparently, I am a slow learner. After cranking down the screws on the carb and doing everything to stop this supposed carb leak, I would check under the hood when I smelled gas and was mistified at how such a small amount of gas could be so strong smelling in the cab.
Well, today I finally pulled my head out of wherever it was and found out that the rubber hose in the fuel filler neck was is cracked and leaking, which of course explains why I had such a strong smell in the cab the first time I filled the thing!
So, the question is, how do I go about replacing the two pieces of rubber hose at the fuel filler neck? Cutting them off will be relatively easy but getting the new ones on is confusing me. Help would be appreciated.I did a bit of searching on the forum and have not found anything relating to this.
Thanks. | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | remove/loosen clamps, pull outward and remove hoses. Install new hoses, shove on and tighten clamps. If you want to remove the tube, it comes out from the inside.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Mar 2015 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 43 | Interesting. It just didn't look like that would work but I will give it a go tomorrow and see how it goes. Thanks! | | | | | Joined: Mar 2015 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 43 | Well, that was a lot easier than I thought it was going to be. Took the two old parts out which was a bit of a pain but managed to go get a couple of new pieces for about $6. Put them back in, in about 10 minutes and now I get to enjoy driving without the strong odor of gas and the fear of being a flaming stovebolt occupant! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Did you get the rubber from a vendor or from your FLAPS???
dg
Denny G Sandwich, IL
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | At $6 I would guess FLAPS! | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Nice truck, and I like the story that goes with it. Welcome to Stovebolt. Steve | | |
