| | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | What is your preference for 3 piece rims paint or powder coat? All 5 rims will be acid dipped then media blasted if necessary to remove all traces of oil grease and penetrating fluid first. Definitely will be Forest Green in color. Just a thought but isn't powder coat after applied thicker than paint and will make it difficult for the clamp ring to seat properly. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 50%/50% opinions:
- epoxy prime and urethane top coat
- powder coat (my powder-coater puts on a "primer" coat and then a finish coat)
Mine are powder-coated semi-gloss black wheel-pieces and cadmium-silver lock-ring (2-ton GMC 20" 3-piece wheels) | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I had mine powder coated semi-gloss black and they have stood up very well with no apparent scratches or dings. | | |
