0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I don't know about your specific situation, but 216s and 235s I have worked on share the no-apparent-reason hole deal. Carl
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I just did a 1959 235 and there is no blocked holes. The head gasket I used was a Fel-Pro Copper. There ARE holes in the gasket that are there for no apparent reason. Its good you are checking before installing the head! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I had something similar on my 216. I believe there is only one gasket made for that motor so I wouldn't worry about it being wrong. Also, I would not soak it in water. I don't use any type of sealer on a composite head gasket | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | Thank You Gentlemen; I was pretty sure there was no issue with a blocked port in the head when there is no corresponding hole in the block. My first concern was that the head was wrong but when compared with the original head all holes line up. I will double check to see if there are any head bolt holes in the block that penetrate the water jacket, thanks for that heads up. Now that the head issue is over I can move forward on the build….once the cash comes back :-)
Have a great weekend!
Mark | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I would be concerned when there is a hole in the block and there is not a matching hole in the head.
I think that the gasket is made to fit more then one specific application. | | |
