| | | Forums66 Topics128,109 Posts1,056,569 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | Ok, fighting through my 58 apache 1/2 ton, going to do whole brake system, having brain lapse on how to remove brake master cylinder from the rod that goes up to brake pedal. It's hanging loose, but the grease fitting area attached to front of master is where I'm confused and I can't locate in manuals or supplements how to remove from that part. Or, do you go up into the engine bay and unbolt from brake pedal and then press that out to install new master? Or, is there something under the zeirdt fitting that I didn't remove holding it there? THANK YOU for your help. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lefty1, there is a bolt retaining a plate which fits in a slot in the pedal pivot shaft. If you remove the bolt you should be able to remove the plate and tap the pivot shaft out of the master cylinder and the pedal releasing the pedal from the master cylinder, hope that helps. | | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | Thank you 3B, my God, I've driven kingpins out of axles easier before. for anyone running future search, remove spring and you can move master around some. Also remove speedo cable to get more swinging room, but you'll still b fighting the exhaust for swinging room. | | |
